81 Deville 8-6-4 continuous fast idle
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, 81 Deville 8-6-4 continuous fast idle in Cadillac Engine Discussion; I need some help in determining what would make my 8-6-4 idle fast all the time. It will not kick ...
    kc81cadman is offline Cadillac Owners Member
    Automobile(s): 81 Sedan DeVille 8-6-4
    Jan 2005
    Toronto Ontario
    20
    I need some help in determining what would make my 8-6-4 idle fast all the time. It will not kick down, so I suspect the the computer is getting bad signals or no signals at all. I believe it to have the quasi injection system, so it may have a solenoid to enrich fuel mixture for fast idle or a funky TPS may be at fault, dunno. If anyone is familiar with this engine and its controls, let me know.
    KC.
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    Re: 81 Deville 8-6-4 continuous fast idle
    Hi KC,
    Find Ape Man on this forum since he knows the V8-6-4 very well.
    Good luck!
    Dave
    Jan 2005
    Toronto Ontario
    20
    Thanks, I will try to PM him if possible.
    KC.
    Darn, not enough post to do a PM, I hope he reads this.
    Jan 2005
    Toronto Ontario
    20
    I got moved! All is better this way. Anywho, does anyone have capabilities to PM Ape Man regarding this issue of mine, it would be much appreciated. I cannot do to limited # of post's, apparently you need 50! Wo, bummer. If someone could accomodate me with an answer it would be great.
    KC.
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    check your idle speed control motor
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Look for binding linkage, vacuum leaks and check the stored ECM codes. Sometimes the ISC motor gets stuck and will cause this. Should set a code or 2.
    Jan 2005
    Toronto Ontario
    20
    Thanks for the info. It is greatly appreciated. I will definetly check out the motor, which I did not even know existed till now.
    KC.
  10. Remove Advertisements
