Intake manifold
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, Intake manifold in Cadillac Engine Discussion; Anybody out there know of Boston area shop that could cut out the plenum for me on intake manifold. I ...
    cady75 is offline Cadillac Owners Member
    Feb 2006
    35
    Intake manifold
    Anybody out there know of Boston area shop that could cut out the plenum for me on intake manifold. I had new exhaust, with modern cat put on magnaflow so now I'm looking front more air in? also with larger opening can I put orignal carb directly on or do I need adaptor. I'm tempted to switch over to Edelbrock. Don't want to affect hood.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Intake manifold
    I'm not around Boston but any automotive machine shop should be able to do it.
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Intake manifold
    Yeah, any machine shop should be able to do it. The original carb will fit directly in place. You aren't do;ing anything but cutting the plenum out. The carb pad will remain the same. You could also do it yourself if you have a bit of know-how and access to a die grinder.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Intake manifold
    The center cut manifold modification will benefit with the addition of a 1" carb spacer as well. If you want to change carbs (I wouldn't, the QJet is IMO the best carb for a street car period) you can use a 1" spacer/square bore adaptor.
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    Re: Intake manifold
    Quote Originally Posted by terrible one
    how many more horses can u get by doing this?
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Intake manifold
    Never been dyno tested AFAIK. But the Edelbrock is apparently worth around 20hp, this flows almost as well - make your own conclusions.
    May 2005
    Columbus, Ohio
    149
    Re: Intake manifold
    thanks bud
  10. Remove Advertisements
