carb question
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, carb question in Cadillac Engine Discussion; its a 68 with a 472, i noticed that the secondaries stay open. the lever piece that pulls them open ...
    68caddycoupedeville is offline Cadillac Owners Member
    May 2005
    19
    carb question
    its a 68 with a 472, i noticed that the secondaries stay open. the lever piece that pulls them open and closed isn't connected to them is there a pin or something that could have fallen off?
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: carb question
    Is it the older white plastic valve that connects to it that is missing or just the link arm itself?
    Make sure nothing is down the secondaries, if they open, it messes up pistons and heads. I have lost a screwdriver bit that way, along with a 307 Olds V8....
    http://www.carburetor.ca/HTML/galler...V247/V247.html
    do these look like it?
    You may need to get a junkyard carb for parts, they are handy....
    May 2005
    19
    Re: carb question
    it looks similer, i'm gonna have to take some pics i'll try to have them up by tonight
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: carb question
    I've got a lot of Quadrajet parts, so if you identify the one you need I could send it out to you if you want.
    May 2005
    19
    Re: carb question
    so i messed around with it and i dont think there is a connecting pin or anything theres just a bar on top that helps it go back down and its kinda wobbly so it moved off track, heres a pic but i works fine now.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: carb question
    CAn you circle the part you are talking about?
    BTW, it's your primary open in that pic...
    autotech is offline Cadillac Owners Member
    Mar 2006
    5
    Re: carb question
    If you had backed up about a foot and took the picture we could probably tell you what it is. From the pix, It looks like the AIR VALVE LOCKOUT of a Quadrajet.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: carb question
    I think the 4M's (like this one) never HAD secondary lockouts, only air valve lockouts. Been a long time, have to dig up my books on them.
    The redesigned (1975 or so) M4 series had them and was a much better design, but was less hot rodder friendly, had leaner calibrations for cruise and a more refined APT (Adjustable Part Throttle adjustments) capabilties.
  11. Remove Advertisements
