472 vacuum diagram
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, 472 vacuum diagram in Cadillac Engine Discussion; well i have these vacuum lines and idk where they go on the carb can anyone help me out...
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    27
    111
    472 vacuum diagram
    man1ey's Avatar
    man1ey is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Aug 2005
    21
    Re: 472 vacuum diagram
    Here's how mine are laid out on a 68 Deville 472 w/ AC:
    Starting at the 12:00 position looking down on the carb from above:
    12:00 to transmission (hard metal tube coming up from beneath firewall
    4:00 to vacuum switch, driver's side of distributor
    6:00 to PCV valve (large line)
    7:00 this one's a pain: line coming from carb 7:00 position and line coming from pull-off diaphragm come together in a T. Third line comes from T over to vacuum switch in to driver's side of distributor.
    10:00 yellow stripe coming in from hvac lines to idle speedup diaphragm.
    Hope these help - I know they could be a little more descriptive but I'm going from memory and can't scan you a pic of the manual right now.
