Some thing wrong with my caddy help
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
500, 472, 425, 368 Discussion, Some thing wrong with my caddy help in Cadillac Engine Discussion; ok my caddy has been parked for like 7 years ok i start it up a year ago ran fine ...
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    27
    111
    ExclamationSome thing wrong with my caddy help
    ok my caddy has been parked for like 7 years ok i start it up a year ago ran fine ok today i put a newer carb on it and now it wont stay started fuel is shooting out of the carb and after car is turned off smoke comes out of the carb and it always does a engine run on what do i do? and how many fuel pumps are on a 1969 cadillac eldorado
    Aaron J Williams's Avatar
    Aaron J Williams is offline Cadillac Owners Member
    Automobile(s): 61 ragtop,2 67 eldos,68 ragtop,68CDV,89SDV,90 fleet,93 ETC
    Apr 2005
    Luck Wisconsin
    50
    75
    Re: Some thing wrong with my caddy help
    There is one fuel pump on a 472 engine but I don't think the fuel pump is the problem. It sounds more like your replacement carb is bad. Did the car act the same with the original carb? It could also be a vacuum leak or sticky intake valve.
    Mar 2006
    27
    111
    Quote Originally Posted by Aaron J Williams
    ok i found anther fuel pump back by the gas tank and there is on up in there motor wtf? and with the original carb it ran great but with his carb its not running great but i just put another carb on the car that my friend had same thing happend and sticky intake vavle??
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    There should not be another fuel pump unless you have EFI, in which case it would be in-tank. Are you sure it's a fuel pump you saw?
    Mar 2006
    27
    111
    Quote Originally Posted by terrible one
    here is a pic of it
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    ^^And what I'm seeing under the inlet or outlet on the left side is an electrical connection? Hmm.
    Anyway if fuel is shooting out of the carb it sounds like the float is adjusted too high. I had a similar thing happen on a Holley carb I was running, my friend adjusted the float the wrong way and we got a geyser of gasoline under the hood... good times.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    I would say that looks like a filter, but the connection has got me as well. Is the mechanical fuel pump up front still there?
    jk1000 is offline Cadillac Owners Member
    May 2004
    tx
    90
    Electric fuel pumps develop much higher pressure than the old mechanical types. Carbs were designed for about 5 to 6 psi, not much more. That electric pump could give you around 40 psi. If you want to use the electric pump then you will need a pressure regulator.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    69 wasn't FI. That must be an add on pump. It may have been out on if the mechanical pump wasn't putting out enough fuel. Sometimes they get weak and work OK in normal driving but don't have enough flow for WOT,or the stock pump may have gone bad and that was someone's fix.
    If you aren't going to drive it hard I wouldn't bother with an electric pump. Take off and get a fuel pressure gauge ( less than $15 @ Harbor Freight )to check the mechanical pump. If it's low, like 2-3 psi, put a new mechanical pump on. Or...just put a new mechanical pump on. It has been sitting for years and probably is weak.
    Mar 2006
    27
    111
    Quote Originally Posted by zonie77
    a year ago i put a new mechanical pump andwas only ran for like 20 min so should i just go buy a new carb?
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by 1969cadillaceldorado
    You have to make sure the fuel pressure is correct first. If it's too high it'll blow right through the carb. Have you tried it without the electric pump?
    Did I understand that you already tried another carb (friend's) and it did the same thing? With or without the elec pump on it?
    Mar 2006
    27
    111
    ok the elec pump has been off this whole time cause it wouldnt stay started with it on and i did try another carb of my friends that use to be on a 75 cadillac and it did the same thing
    Mar 2006
    27
    111
    ok went out and started it up again to see maybe if it would stay running well it did for 5min 2min later a girls walks up ans says thanks for messing up my tuesday cause of my car being so loud she couldnt hear her tv so she started to say something to i just revved it she walked away and then here comes that fuel out of the carb so that was gay but she called the cops on me and the cop said i can only run my car from 7 in the morning to 7 at night im only running open exhaust like its that loud LOL
  16. #14
    Sep 2003
    Arizona
    3,531
    Forget the elec pump. Leave it off.
    I'd get the gauge and check the pressure. it should stay about 5psi. I think 7psi is the highest a carb can handle.
    If it's in the right range then get another carb.
    Did you buy that one rebuilt? Why not return it?
    You said it ran with the stock carb. Why not use the stock one?
    Rebuilding carbs isn't that hard but there are a bunch of small parts. If you have an extra carb now maybe you should try rebuilding it.
  17. #15
    Mar 2006
    27
    111
    no i got another carb off my part car its 69 eldorado to it was was rebuilt like 20 years ago the the stock one rite where the fuel line goes in the carb it start to leak there so thats why i put this carb on and where would i get this gauge
  18. Remove Advertisements
