Some thing wrong with my caddy help - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
500, 472, 425, 368 Discussion, Some thing wrong with my caddy help in Cadillac Engine Discussion; There's a metal "gasket" that's called the valley pan below the intake manifolds that seals oil in the lifter valley ...
  1. #31
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Some thing wrong with my caddy help
    There's a metal "gasket" that's called the valley pan below the intake manifolds that seals oil in the lifter valley and seals the intake manifold to the heads. Regular carb gasket under the carb.
  2. #32
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    26
    111
    ok thusday going to take off intake manifold and go order new champion carb from autozone for $148 and spark plugs and wires so i hope my car runs good
  3. #33
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I hope so as well. I still reccomend against the autozone carb. You will likely need to tune it, most off the shelf carbs are designed for the mainstream Chevy and Ford small blocks. On a Cadillac Big Block the carb will see a much more "sharp" vacuum signal. I can almost guarantee it will run rich out of the box.
  5. #34
    Mar 2006
    26
    111
    Quote Originally Posted by davesdeville
    ok how would i tune the carb?
  6. #35
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Heh. A Champion carb? Hell if I know. Hope it comes with instructions...
  7. Remove Advertisements
