500 casting numbers
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, 500 casting numbers in Cadillac Engine Discussion; i recently bought what is supposed to be a 1975 500 c.i. motor. the casting number is #1486200 and the ...
    earp is offline Cadillac Owners Member
    Mar 2006
    500 casting numbers
    motor. the casting number is #1486200 and the intake
    nuber is #1605061. i have a couple of lists showing
    casting numbers but find that exact number. can anyone
    help with this? any help would be appreciated.
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Re: 500 casting numbers
    If you look closer, I'm sure that you'll see that the block casting number actually ends with "5200". 472's and 500's from '70-'76 used the same block so that number will only tell you that it is a 70-76 472/500. To know for sure you need to check the stroke and the design of the pistons.
    Here's a site that should help you.
    http://www.geocities.com/MotorCity/P.../Engineid.html
    Mar 2006
    thanks.
