best way
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, best way in Cadillac Engine Discussion; Hello, I have a 1980 deville, 368, what is best way to flush cooling system to flush block and rad ...
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    best way
    to flush block and rad too ?. tx Ken
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: best way
    Firstly, I think they make a chemical made to clean out the block's cooling passages. With that being said:
    Disconnect rad hoses,
    Remove rad (if you want to get it rodded out or something)
    Coolant will come rushing out
    Stick a waterhose in the lower hole and let it get what's left out.
    Then,
    You can either put it all back together with new coolant, or if it has a lot of dirt/rust/corroding or whatever, you can put some stuff in there designed to clean it out, and drive around for a bit like that (instructions should be on the bottle) and then you put regular coolant in.
    That is how I would do it at least.
    burnrubber is offline Banned
    Feb 2006
    Port Barre, LA
    30
    Re: best way
    IN the truck shop I used to work at - we'd use Cascade detegent to flush cooling systems. Run them for an hour or so - then drain them. Shoot water through the upper inlet on the radiator - and if your water pump is off, shoot water through both ports on the engine.
    Feb 2006
    Port Barre, LA
    30
    Re: best way
    OOps. I meant detergent.
    Nov 2005
    3,013
    Re: best way
    Thank you both for your advice, also burn rubber, how much cascade det. would you use?.
    Feb 2006
    Port Barre, LA
    30
    Re: best way
    I'd use probably a cup or so with a car cooling system (I am talking of the powder detergent). Run that with water and drain it. Do that till you think its clean. Then run straight water through it till it comes out clean. Its a little time consuming but it seems to work well - better than those bottles of radiator flush.
    oldsalt's Avatar
    oldsalt is offline Cadillac Owners Member
    Feb 2006
    texas
    7
    Re: best way
    I flush my systems with the heater on and water circulating thru that system as well. Also dosen't hurt to run the heat once or twice during the summer months so that those lines don't sit stagnent.
    Nov 2005
    3,013
    Re: best way
    Thanks for the good advice.
  11. Remove Advertisements
