Good Cam for my 1970 Eldo
Results 1 to 9 of 9
500, 472, 425, 368 Discussion, Good Cam for my 1970 Eldo in Cadillac Engine Discussion; I'm looking for a cam for my Eldorado, I'm putting new springs lifters and a cam in, do you guys ...
    JimsEldorado is offline Cadillac Owners Member
    Nov 2005
    68
    and a cam in, do you guys know of a good cam that would give
    me MORE tourqe than the stock one without modding my heads?
    Thanks!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Good Cam for my 1970 Eldo
    You'll want to contact the vendor of your choice, Potter, MTS, Torque Inc, Flashcraft. Something like the 3 series grind from MTS...
    http://www.cadillacowners.com/vendors.html
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    If you aren't phone shy, call up Potter or MTS and talk to them about what you want to do and they can set you up with a custom grind from Comp Cams
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    30
    857
    Cad Company also has a WIDE selection of cams. It also seems to me that CadCo puts ALOT of research into cam applications.
    Nov 2005
    68
    I think I'm gonna go witha a Comp Cams 260 H cam, is this
    a good choice?
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Post the specs.
    Nov 2005
    68
    Camshaft Specification Table
    Part Number94-302-5 Engine1963-1979 Cadillac
    425ci-500ci
    8cyl.
    Grind Number CAD 260H-10 DescriptionIntakeExhaustValve Adjustment0 0 Gross Valve Lift0.481 0.481 Duration At 0.006 Tappet Lift260 260 Valve Timing At 0.006 OpenCloseIntake24 56 Exhaust64 16 These Specs Are For The Cam Installed At 106 Intake CLIntakeExhaustDuration At 0.05 212 212 Lobe Lift0.2795 0.2795 Lobe Separation110
    May 2005
    El Dorado, Arkansas
    26
    1,631
    That's not much of a cam. That isn't much more lift than stock is it?+
    Aug 2003
    Albuquerque, NM
    29
    7,971
    That is pretty close to a stock cam. In fact it may be even less agressive than the 72-73 cams. I don't see it doing a whole lot, but the updated lobe profile (IE the intake valve doesn't open redonkulously late like the stock cam did) would help a bit. I personally would go with something a touch more agressive than that, around .510-.510 lift, 215-220* duration @ .050. BUT god knows I'm no cam expert. If I were you I'd talk to one of the cam vendors directly
  12. Remove Advertisements
