500 cid head question?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 500 cid head question? in Cadillac Engine Discussion; Hello, I've got a 74 eldo with 500 engine, I just need to know what yr. did Cadillac set the ...
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    Hello,
    I've got a 74 eldo with 500 engine, I just need to know what yr. did Cadillac set the heads up to run on unleaded gasoline?
    Also with the oil pump being external. Is the pickup screen located in the pan?
    I'm getting ready to revive it after 10yrs, and will definitely have head work done if nothing else.
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Re: 500 cid head question?
    Quote Originally Posted by 74eldog
    Hello,
    It has been said that these heads are hard enough to not need hardened seats because of the high nickel content. I'd have them inspected by a reputable shop. If the seats are in good shape, leave them alone.
    The pick-up is located inside the pan.
    May 2005
    Columbus, Ohio
    149
    Quote Originally Posted by lux hauler
    Thanks much...
    Where are you located in Ohio, I'm in Columbus
    Jan 2003
    Ohio
    47
    1,258
    Thanks much...
    No problem....I'm just west of Cleveland.
  7. Remove Advertisements
