Results 1 to 2 of 2
Thread: 1968 472 Oil pump rebuild
    May 2004
    Longview Tx
    31
    250
    Can anyone tell me how to remove the oil filter by-pass valve and the spring from the oil pump on a 1968 472 or if its even at all possible.any help will be much appreciated
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Re: 1968 472 Oil pump rebuild
    Unscrew the allen plug on the housing and they should slide out. Let us know if this works out for you. The stock pumps do work well with a rebuild but I would recommend the cast iron melling replacement pumps. They seem to make better pressure and last longer. - Justin
  • You may not post replies
