Results 1 to 9 of 9
Thread: what is it......?
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    what is it......?
    Hello, I have to hacksaw my fuel line near my carb(1980 deville 6.0 ltr. 4 barrel rochester carb.) I cannot get 5/8" flare nut off. I want to send carb. in
    to be rebuilt. does anyone know what material fuel line is, it looks like it could be stainless steel, I hope not.
    tnx ken
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: what is it......?
    I'm not sure what it is off the top of my head, but it bent fairly easily on my car, I can tell you that much...
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    It should be double wall steel pipe, but not stainless.
    You could try to spray the nut with some rust penetrant a few days in a row and see if that will let the pipe break loose from the nut, but it may not work. They used to do that a lot.
    You can cut through the pipe, just try to do it on a straight section of the pipe so you can install a section of "repair hose" and clamps later on.
    The best thing to do would be to replace the pipe from end to end but they don't prefabricate them so you'd have to make it yourself, not an easy undertaking.
    Carbs didn't have much fuel pressure so patching it with fuel hose should be relatively safe.
  5. #4
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    I would say spray it down with PB, let it sit a day, and then have at it. Mine didn't want to come loose either, but that and the carb being mounted on the intake still helped.
  6. #5
    Nov 2005
    3,013
    Tnx. for your advice
  7. #6
    Aug 2005
    Kansas City, ks area
    53
    37
    Like ewill3rd said, cut it on a straight part. And when you replace that part with rubber hose, get an inline filter and toss the one in the carb. They suck...
  8. #7
    Dec 2005
    arizona
    30
    38
    hey creeker how does that 368 run..it dosent have the v8-6-4 im sure right!cause that one had some problems with it..so im just wondering how the 368 ran rather than the v8-6-4.. cause i want to look in to getting the 368 ci without the v-8-6-4...your has roughly 150 hp right??
  9. #8
    Aaron J Williams's Avatar
    Aaron J Williams is offline Cadillac Owners Member
    Automobile(s): 61 ragtop,2 67 eldos,68 ragtop,68CDV,89SDV,90 fleet,93 ETC
    Apr 2005
    Luck Wisconsin
    50
    75
    Cant you just unplug the V8-6-4 wiring or controller to get it to stay a V8?
  10. #9
    Aug 2003
    Albuquerque, NM
    29
    7,971
    You can cut or put a switch in the wire coming from the transmission that lets the controller know the car is in 3rd gear to disable the modulated displacement function. But it won't make the car run any differantly if the MD function is working properly. Assuming the DFI system is working as well, a MD motor should run better than a carbureted 368.
  • You may not post replies
