camshaft kit for 425 engine
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, camshaft kit for 425 engine in Cadillac Engine Discussion; My original camshaft seems to be worn down after 100000 miles. intend to replace it with a new one with ...
    kger is offline Cadillac Owners Member
    May 2004
    Switzerland
    55
    4
    My original camshaft seems to be worn down after 100000 miles. intend to replace it with a new one with smooth idling characteristics and some torque/performance increase.
    Any ideas/expirience with a supplier and type of camshaft that I could use instead of the one with original specs? is there a supplier that offers camshaft kits that include all the necessary parts (gaskets,etc) that are recommended for a camshaft replacement.
    thanks for your comments...
    gerry
    (switzerland)
    ps:Not looking for hot rod equipment...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: camshaft kit for 425 engine
    All the "Hot Rod" Cadillac performance places sell milder improvement cams. And how do you know the cam is worn down? 100,000 miles is nothing for a 425! I can't imagine it'd be worn down so soon!
    Check with MTS and Cad Company for some torque improvement cams, like thier RV cams. You may need to upgrade the rocker arms and springs, some of the cams may just require new springs.
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    All BB Cad cams will work for the 425.
    my 425 has 93k miles.... yet runs as good as ever despite all the sludge buildup in side (under the valve covers... not that bad but eh) and the rebuilt carb could use a little tune... cam seems fine tho.
    For stock engine I would say an MTS #3 or #5. The #3 will move the power band LOWER then stock, but with the stock 2.28 gears on the '77-'79 DeVille, it would actually be a better cam... not to mention it is the fuel economy cam, so expect a nice boost in MPG If you want a little more mid-upper end, the #5 is a good choice... it is an updated version of the hottest factory cam... 1972 IIRC? that in a 425 would be a nice improvement as well. The #10, I like but it is pushing the stock valve train (weak link) a little too far for my liking.
    If it was me, I would get the #3, just because I have the 2.28 gears, and while I would like to change them, it isn't happeneing soon. Not to mention the car may get low 20's MPG on the highway... it gets 16mpg on the highway as it is now...
    cadillacdeville's Avatar
    cadillacdeville is offline Cadillac Owners Fanatic
    May 2004
    Longview Tx
    31
    250
    Here are a few specs for you. The stock cam valve lift is .457" intake and .473" exhaust
    MTS says the #3 valve lift runs .470-.480 not sure if thats (intake-exhaust)
    that will run around $190.00
    Summit racing has Competition brand cams CCA-94-300-5 runs .465 lift intake and exhaust for $154.69 you can go a little higher for CCA-94-302-5 which runs .481 lift intake and exhaust also for $154.69
    To me it sounds like Competitions CCA-94-300-5 would be a good choice for a close to stock with a little better performance I was unable to find any complete cam kits
    However partsamerica.com has a timing cover gasket set from Fel Pro that looks to have every thing you would need to swap out a cam
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Does anyone know the lobe separation and duration of the stock factory Cadillac 472/500 cams?
    - Justin
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    Quote Originally Posted by cadillacdeville
    If I were doing anything with my 425, and going with an MTS cam, I would personally get a regrind.... just as good, but $120
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I agree, a VT3 or 5 (reground by Erson) would be great. Use some of the cheap springs while you're in there. Anything is an improvement over a stock cam. The intake opens very late on a stock cam apparently, some say it was to help keep air velocity up... I don't buy it, get anything but a stock spec regrind.
  10. Remove Advertisements
