69 472 spec's
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, 69 472 spec's in Cadillac Engine Discussion; Does any one know the spec's for the 69 472 engine? HP torque comp ratio TIA...
    hardley-etc is offline Cadillac Owners Fanatic
    Automobile(s): 94 ETC 78 Eldo 69 Eldo
    Jul 2004
    PA
    170
    69 472 spec's
    69 472 engine?
    HP
    torque
    comp ratio
    TIA
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 69 472 spec's
    375 HP Gross
    525 lbs-ft of torque Gross
    I believe the compression ratio was 10:1.
    Jul 2004
    PA
    170
    Re: 69 472 spec's
    thanks
    just bought a 69 eldorado
    only flaw, is a rip in the seat, that i could find
    hood and trunk need buffed
    and two small dime size rust spots on the bottom left corner of the trunk lid
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 69 472 spec's
    Cool! Post some pics when you can!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: 69 472 spec's
    I'd say 300hp and near 480ft.lbs is a realistic estimate of what that motor would put through a dyno today.
    Should be 10.5:1 for 69, although I've heard the early high compression motors had actually substantially less compression than advertised.
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    26
    111
    Re: 69 472 spec's
    1969 cadillac specs 375hp, 525tq,10.5:1
  9. Remove Advertisements
