rebuilding engines
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, rebuilding engines in Cadillac Engine Discussion; hello im going to be rebuilding my 472's. the first one im rebuilding stock or semi stock i was wondering ...
    Prince BY-TOR is offline Cadillac Owners Member
    Mar 2005
    kentucky
    34
    rebuilding engines
    hello im going to be rebuilding my 472's. the first one im rebuilding stock or semi stock i was wondering what are the bennefits of a high flow or pressure oil pump and which cams from the vendors are slightly better than stock? are there any small things i can do to increase the overall horsepower output slightly? thanks
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: rebuilding engines
    Cut the center out of the intake(s) for starters.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I would go buy a melling oil pump. As far as cams go, all the vendors have mild cams that are an improvement over the stock cam. A mild cam, lifter, and spring kit shouldn't be much more than $350. You'll probably still need the valve guides milled for clearance even with a mild cam in order to keep rocker arms from running into them.
    Do cut the center out of the intake manifold.
    Upgrade to HEI if you haven't already.
    Get a local shop to make you a nice dual exhaust system.
    If you want more power put a 150 shot on it.
