Go 425! - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
500, 472, 425, 368 Discussion, Go 425! in Cadillac Engine Discussion; Originally Posted by Night Wolf Wait... '79 Fleetwood has rear sway bar and DeVille dosn't? Can this sway bar be ...
  1. #31
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Go 425!
    Quote Originally Posted by Night Wolf
    Can this sway bar be installed on the stock 2.28 DeVille rear end?
    I know, the aluminum hood is sweet! The '79 Fleetwood at the junkyard has it, but the damn thing has some dents and stuff... I dunno man, it is only $35, so I should just get it....
    Yeah, my '79 Deville doesn't have a rear sway bar! I'm adding one with my new rear. I would think the one from the Fleetwood could be installed on the Deville with no problems. I think the holes in the lower control arms are there to mount it.
    I'd grab that aluminum hood! $35 sounds like a great price, and with how some people can work thier magic on aluminum, it should be no problem to fix. That is unless it's really trashed! Be sure to grab the hood hinges and springs, they are different and the springs are weaker since the hood weighs like 60 pounds less!
  2. #32
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    Re: Go 425!
    Wow, so I'll check out that sway bar tomorrow! Is it simply bolted up and stuff? easy to come off?
    The hood is in pretty nice overall shape... in fact yesterday I thought it was mint, really, I should get it.
    So the hinges and springs really are that different? is it easy to unbolt from the chassis of the car to remove?
    here is the big question:
    *will the hood of a '79 DeVille fit into the trunk of said '79 DeVille!?!?*
  3. #33
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Go 425!
    The sway bar is bolted to the lower control arms. They should be easy to get out from under the car. I'd definetely grab that hood! And yes, the springs for the hood are much smaller! I'm not too sure if the hinges are different, but I'd just take them anyways! The hinges are just held on by 3 bolts on each hinge, and then the 3? that hold it to the hood.
    I doubt the hood will fit in your trunk, but take an old blanket and some ratcheting tie downs, and strap that sucker to the roof of your Deville!
    Good luck!
  5. #34
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Go 425!
    Be sure to grab the pieces that fit inside the trailing arms. These are tapped out to accept the bolts and should be sprayed with WD-40 ahead of time or the threads will pull out. All the cars that I've seen came through with the holes for the swaybar mounts. Once in a while you might see one trailing arm that is turned around backwards. Mid 70's MonteCarlo and GranPrix have heavy rear bars which fit these cars too.
  6. #35
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    Re: Go 425!
    Quote Originally Posted by caddydaddy
    Good luck!
    Nice, I'll definitly look at that sway bar today
    The roof... eh...
    The junkyard is about 10mins, if that, from my apartment... I was thinking kinda jamb it sideways in the trunk and bungee cord it down, I'll have to see.
  7. #36
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    Re: Go 425!
    Quote Originally Posted by The Ape Man
    How hard are those pieces to get at?
    There are a handful of the 70's Monte/Prixs there too....
  8. #37
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    30
    34,087
    Re: Go 425!
    Rick, grab the hood ornaments off the Fleetwoods so you can have the wreath AND crest!
  9. #38
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Go 425!
    As long as the car is not sunk into the ground then you should be OK. Bring box wrenches to get to the bolts that might be hard to reach. No point in removing the swaybar from the mounts either. Leave those large bolts in place. The mounts are constructed like 3 sided square tubing. They are shaped like the letter E without the - .
  10. #39
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    Re: Go 425!
    Quote Originally Posted by I~LUV~Caddys8792
    I already do
    brand new old stock off ebay... been on the car for a while now.
  11. #40
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    Re: Go 425!
    ahhh, ok, so remove the mounts with the swab bar left intact?
    I'll bring the WD-40 too....
    Nope, car is pretty high off the ground actually, they have 2 steels wheels welded, 1 is flat the other is upright, about 4 of those the whole car is sitting on... yeah, it can be a little scary, but I was pushing it and it was pretty stable, the tires are rmoved and the rear end is just laying there (car is held up by body)
  12. Remove Advertisements
