Pictures of 425.... - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
500, 472, 425, 368 Discussion, Pictures of 425.... in Cadillac Engine Discussion; Economy lamp. Runs on vacuum signal. Low vac, light comes on. See you at the gas station....
  1. #16
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Pictures of 425....
  2. #17
    bigblockcaddy is offline Cadillac Owners Member
    Dec 2005
    arizona
    29
    38
    wait what does that mean,low vac from what?
  3. #18
    Dec 2005
    arizona
    29
    38
    if anyone that has a 77 78 or 79 caddy they do have this light and does anyone else have anymore ideas
  5. #19
    Feb 2005
    Southern NJ
    54
    2,096
    Low vac is normal when you step on the gas pedal with meaning,
    Low vac also happens with poor tune and medium throttle angle.
  6. #20
    Dec 2005
    arizona
    29
    38
    what would i need to get to fix it ?
  7. #21
    Feb 2005
    Southern NJ
    54
    2,096
    More throttle = less manifold vacuum. The light turns on when manifold vacuum drops below a set number. It is telling you that you would get better gas mileage if you didn't step on it enough to make the lamp come on. Think of it like having your wife in the passenger seat telling you to slow down. It's not an indication of any fault. The lamp will come on more if the engine tune isn't really good. Things like worn out ignition components and vacuum leaks will make the engine run with less vacuum.
    If you get reasonable performance and fuel economy with the car then nothing is wrong with it.
  8. #22
    Dec 2005
    arizona
    29
    38
    i have a like a half dollar size hole in my auto thermac hose ..would that have anything to do with it?
  9. Remove Advertisements
