80 dev. fuel filter
Results 1 to 11 of 11
500, 472, 425, 368 Discussion, 80 dev. fuel filter in Cadillac Engine Discussion; Need some help, I want to put a new fuel filter in 1980 deville, 368, it's right in the carb ...
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    80 dev. fuel filter
    Need some help, I want to put a new fuel filter in 1980 deville, 368, it's right in the carb body, and involves two wrenchs to remove old one. one of the wrenches is a 15/16" , the other wrench ( to remove fuel line) is somewhere around a 9/16, 1/2, or ??. one is too small and the other is sloppy and might round soft nut. does anyone know actual size?. tkanks.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 80 dev. fuel filter
    It's a 5/8" nut. 16 mm will work fine also. You should use a tubing wrench for the job. Sometimes a tubing wrench can be forced onto rounded nuts by rocking it while applying a lot of pressure.
    Nov 2005
    3,013
    Thank you , knowing what to use is half the battle.
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    30
    857
    Does that filter serve as an auxillary? I know the q-jets on the BBC's (any engine for that matter) have either a paper filter or a mesh filter. My '68 has a mesh filter with a large primary filter under the pump... Do the q-jets with a paper filter also have a large primary?
    Nov 2005
    3,013
    I have only owned car for a month, but as far as I can find out it only has the one filter, it is quite small , approx. 1/2" dia. by 3" long. with a built in "check valve". I also bought an inline filter that I will install sometime.
    tnx. for reply
    cadder2000 is offline Cadillac Owners Member
    Automobile(s): 1982 fleetwood w/ 500cid, 1990 Brougham 'D Elegance 5.7
    May 2004
    Phoenix,AZ
    39
    18
    Check the frame rail about 3/4 of the way back, on the drivers side. There should be a bigger primary one.
    Nov 2005
    3,013
    Cadder 2000, tnx. for the tip,would it look like an inline filter ? is it a factory installed item?. tnx. ken
    Feb 2005
    Southern NJ
    54
    2,096
    You won't find a fuel filter on the frame rail of a carburated 1980 Cadillac unless someone modified it. You might be thinking of the fuel injected models.
    The filter in the fuel pump isn't there on later models either.
    Nov 2005
    3,013
    yes , my car has a carburetor, so I guess there's just the one filter in the carb. and none on the frame.
    Mar 2004
    30
    857
    Quote Originally Posted by The Ape Man
    Well mine is in-line but right under the pump. Its a stock setup as i have seen it in my manual.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by JTraik
    The older cars had a filter right in the pump. Later ones I've seen didn't use that filter. Some had both filters.
  14. Remove Advertisements
