472 pictures put together out of car
Results 1 to 12 of 12
500, 472, 425, 368 Discussion, 472 pictures put together out of car in Cadillac Engine Discussion; I need to see how the belts are routed and basically how everything goes on the front of the motor.....any ...
    CHROMIE HOMIE is offline Cadillac Owners Member
    Nov 2005
    4
    I need to see how the belts are routed and basically how everything goes on the front of the motor.....any picture can be sent to my email sean.rosser@sbc.com thanks in advance
    Nov 2005
    4
    Re: 472 pictures put together out of car
    here is what I have so far
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Here's a diagram from my shop manual. Hope this helps!
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Hey Chromie Homie,
    That engine looks sweet. How much did it cost you to chrome everything? How much did that engine paint cost you? Is that a 472 or 500? - Justin
    May 2005
    El Dorado, Arkansas
    26
    1,631
    I hope those exhaust manifold are ceramic coated, and not chromed! Is that engine enamel?
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    Dayum, that's shiny! Be careful opening the hood on a sunny day, the reflections from that fan spinning might down small aircraft!
    I presume you are not putting a somg pump pack on, or never had one, so...
    I'd grab an alternator belt for a '70 Caddy, run it crank, water pump, alternator.
    For the power steering, I think you'll be on your own, all the stock belts for the power steering ran around the AC compressor so would be way too long. You might try the alternator belt on that side, that might work. , but you'll probably need one a bit shorter, and run it crank, water pump, power steering. There are two grooves for that routing, but I think that was mainly because of the AC, so you can probably just run one belt to the power steering.
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    wow... that is a nice looking engine.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    The power steering pump body is spaced away from the block on the 2 adjuster mounts. If you don't space the pump the belt will not line up and wear develop a fugazy wear pattern. A couple a three washers work here if you don't have the original specialty hardware.
    Nov 2005
    4
    Thanks for the compliments, diagrams and suggestions. Someone asked if the manifolds were chrome...yeas they are. I realize they may turn a little but not as bad as headers because they are a thicker metal. besides I had them ceramic coated first and it looked HORRIBLE with all that chrome.
    It is a 472 not a 500 and I have between 1500 and 2000 in plating on the motor. not sure how much I have total because some things were upgraded. all chrome holley: $625.00 building a chromed out and candy 472: PRICELESS
    May 2005
    El Dorado, Arkansas
    26
    1,631
    I like the paint color.
    Nov 2005
    4
    Quote Originally Posted by terrible one
    STDog is offline Banned
    Dec 2005
    4
    Hey Chromie, did you ever get this together?
    For the P/S belt, I could check my manual for the correct size.
    Remember you could buy the cars without A/C (heat only) it uses the short belt. I think autozone.com will give you the correct P/N if you look up a 68-72 Deville w/o A/C. Some stores and some sites don't list it for certain years though. But, the 68-72 cars all had the double belt for P/S and A/C. Find the no-A/C P/S betlt for one of those years.
  15. Remove Advertisements
