Ultimate Database/FAQ of the 500 | 472 | 425 | 368 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Like Tree1Likes
500, 472, 425, 368 Discussion, Ultimate Database/FAQ of the 500 | 472 | 425 | 368 in Cadillac Engine Discussion; A tidbit of info on the 368 engine. Often overlooked because it's so darned hard to see.The EFE valve which ...
  1. #16
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: Ultimate Database/FAQ of the 500 | 472 | 425 | 368
    A tidbit of info on the 368 engine. Often overlooked because it's so darned hard to see.The EFE valve which is on the exhaust manifold, passenger side.The purpose is to direct hot exhaust gases through the intake manifold during cold startup. The shaft on this valve must be kept lubricated and moving freely because it is operated on vacuum only.Some of the symptoms of a sticky or non functioning EFE are as follows. Poor operation at start-up(rough idle, stumble) Poor operation after warm-up (lack of high speed performance,surge,miss at all speeds) The EFE is controlled by the TVS (Thermostatic Vacuum Switch) on the 6.0 and electronically on the 4.1 engine. The TVS is located on the left front of the cylinder block . Make sure the vac. lines to the EFE are sound and have tight connections.
  2. #17
    67SDV472ci is offline Cadillac Owners Member
    Automobile(s): 1967 sdv with 73 472
    Jan 2015
    15
    Just something i learned. Frankenstein-ing caddy bigblocks. 425 heads on a 472/500 will add compression.
  3. Remove Advertisements
