Distributor Points Screws and Pertronix - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Like Tree2Likes
500, 472, 425, 368 Discussion, Distributor Points Screws and Pertronix in Cadillac Engine Discussion; I believe the thread is an 8/32 x 1/4"...I had a 8/32 x 1/2" and that was too long. I ...
  1. #16
    Cristofo's Avatar
    Cristofo is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Sedan DeVille (Sold), 1970 Cadillac Coupe DeVille
    Apr 2009
    Philadelphia
    34
    259
    Re: Distributor Points Screws and Pertronix
    I believe the thread is an 8/32 x 1/4"...I had a 8/32 x 1/2" and that was too long. I will go to home depot or lowes to see if they have the correct size screws I need. I also checked my idle mixture screws and they seemed to be way to far out, I rotated clockwise until they were lightly seated and I will go from there when I get the car started again. I will go counter-clockwise 6 turns and adjust from there.
  2. #17
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Just to follow up, never lose your points screws or you will need to buy a replacement distributor or find one in a junkyard somewhere that still has the distributor so you can get the screws. Otherwise, you need a 8/32 x 1/4" give or take length for those screws if anyone is curious. Every place I went to look doesn't carry a size that small, home depot, lowes, local hardware store. I'm sure I can order them online somewhere, but thats always my last resort for something like this.
  3. #18
    chrisntam is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Deville Convertible
    Oct 2012
    North Texas
    309
    I see the factory service manual (on eBay) sold based on the "best offer". Was it you??? Hope so! It's pretty nice to have it to browse through. I like it so much, I have two of them.
    On the screws, what about going to a "hardware" store? I mean a true, old fashioned one, not like Ace or True Value. I bet they have what you need. What about a nut/bolt supplier in the area? If the hardware store doesn't have them, ask them who their supplier is. What about grinding or cutting down a longer one to get to the 1/4" length? Not sure how you'd hold it while grinding or filing.
  5. #19
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Quote Originally Posted by chrisntam View Post
    I ended up grabbing a 3/8" length and using a nut as the spacer to make up the length, its now nice and tight with new screws that are not taper head. The car is running great after I adjusted the idle screws today, but they might still need some adjustment since they're at the base setting 6 turns out.
    I saw in the factory manual, the wire I'm looking for is the 12P wire that connects to the 20W resistor wire that goes to the coil. The wire comes through the firewall under the dash as a 12 gauge Pink wire. I will hook the pertronix red wire up to that pink wire and call it a day. Not sure if the accel super coil is supposed to run on 12V also but it seems the directions say to bypass the resistor wire also. I could run both the coil and pertronix up on my 12V source and that seems to be the correct way to wire them if i'm reading correctly.
  6. #20
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    Update and conclusion:
    Finally replaced the screws that held the Pertronix module to the breaker plate (8/32 x 1/4"). I also ran a new wire to run the Pertronix and Accel Super Coil on 12V and the car runs great. I also ended up replacing the spark plugs and inline fuel filter. Car accelerates with no hesitation and is smooth and strong throughout the RPM range.
  7. #21
    Oct 2012
    North Texas
    309
    I had a quick laugh when you said "conclusion". I thought, there is never a conclusion with these cars!
    But in reading your post, you are correct! Great to hear it's all working and working well!
    chris.
  8. #22
    Cristofo's Avatar
    Apr 2009
    Philadelphia
    34
    259
    chris.
    haha ain't that the truth, really just on to the next thing. I'm glad to have the engine running the way it does, now I can focus on removing the vinyl top, fixing the back window rust/leaks and then onto the interior. I should be done sometime in 2018 haha.
  9. Remove Advertisements
