1973 500 Cu. In. Question
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1973 500 Cu. In. Question in Cadillac Engine Discussion; Will I have any problems mainting this engine, with regards to parts?...
    caffine1973 is offline Cadillac Owners Member
    Oct 2005
    5
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: 1973 500 Cu. In. Question
    Is there anythign wrong with it?
    There is a semi-big, ever-growing 500 ci aftermarket
    472's Avatar
    472
    472 is offline Cadillac Owners Fanatic
    Automobile(s): 55 60S, 81 DeVille (Diesel), 83 Coupe (507), 84 Wood (425)
    Dec 2004
    PDX
    33
    119
    Maintainence is no problem as the fundamental parts are common for other engines. Tune up parts are very available and relatively inexpensive. Even other items like gaskets or bolt ons (water pump, starter, alternator) are as available as the small stuff. Broadly speaking, I feel it's an engine easier to work on than a small block Chevy (dist in front, plugs above manifold, external oil pump, etc).
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    No problems doing maintenance - it's a Caddy, nothing ever breaks!
    I'm kidding of course.
    But, the big tune-up parts, distributor and carburetor use parts shared across basically the entire GM line. Internally, the distributor is the same as that used on Chevy V8's (both big and small block) and is probably common with the distributors on other GM brands. The Q-jet was used on V8's across basically every GM line, so rebuild kits are common and readily available. Brake pads are the same - the same pads used on fullsize GM cars and trucks from '69 untill sometime in the 90's.
    Ain't parts interchangability great! Eli Whitney would be proud!
    I also agree with 472 about it being easy to work on. Everything you need to get to is out there and reachable. Even the oil filter isn't hard to get to. Of course, with the acerage available under the hood...
  7. Remove Advertisements
