Lets have a vote... - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
500, 472, 425, 368 Discussion, Lets have a vote... in Cadillac Engine Discussion; Doesn't come with the injectors. I think I understand, I'll do a bit of research. In your opinion, do you ...
  1. #31
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Lets have a vote...
    In your opinion, do you think that I should do this? I've been told that its going to be a pain getting it to work right, etc etc. I kind of halfway just want to go with the carb...
  2. #32
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    I don't think it is a good idea to dump the PCV valve.... it really dosn't do anything but help, same as EGR (when working correctly) ....
  3. #33
    May 2005
    El Dorado, Arkansas
    26
    1,631
    MTS sells brand new stock replacement injectors. Would those be ideal?
    Dumping the PCV valve makes it easier on me. I'm dumping the EGR for flow reasons.
  5. #34
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I'm not sure the stock size injectors are good for flowing enough fuel for a warmed up engine. Then again they might be. Ask Al.
    PCV gets rid of nasty ass blowby gasses. My reccomendation is to keep it if you can.
  6. #35
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Yeah, good idea. Ask Al.
    What are blowby gases?
  7. #36
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by terrible one
    No reason to use stock early EFI injectors if you are running a Megasquirt. Those injectors command collector prices. They are also low impedance and place different demands on the switching semiconductors. Better off with a common newer type. I'd ask around on the Megasquirt message board to see if anyone knows what else fits in there. Keep the PCV. Keep the EGR unless you are trying to make every last drop of power and completely ignoring economy. It should not make any difference at wide open throttle but can allow you to use more timing at cruise.
  8. #37
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    PCV is Positive Crankcase Ventalation... which is just that... it allows the blowby gasses to be recycled.... without it, or with a bad PCV valve, the engine can sluge up rather easy...
    the blow by gasses are whats left of the fuel/air mixture, that managed to slep between the cylinder walls and the rings... blow by..... now all that stuff is stuck in the crank case with no where to go... but the PCV valve simple takes that gas and usually dumps it in the valve cover or intake manifold... I vote to keep it, it does no harm and a new PCV valve is $3.
  9. #38
    May 2005
    El Dorado, Arkansas
    26
    1,631
    So on my manifolds (not stock) can I just drill another 1.25" hole for the PCV valve, get a new valve and grommet, and be good to go?
    I'm going to be using a pre-egr manifold for flow reasons.
  10. Remove Advertisements
