368 to 472 swap issues
Results 1 to 15 of 15
500, 472, 425, 368 Discussion, 368 to 472 swap issues in Cadillac Engine Discussion; I am swapping out the 368 for a 472 in my car, its a 1948 Packard on a 80's ? ...
    Howsha Fern is offline Cadillac Owners Member
    Automobile(s): 1977? deville?
    Sep 2011
    41
    4
    I am swapping out the 368 for a 472 in my car, its a 1948 Packard on a 80's ? model Cadillac frame and drive train. I know the 368 was only used a short time so that will help me figure out what the frame under this car is too.
    My problem i just ran into is. the oil pan hitting the cross member when i tried to place the motor. im not sure the year 472 motor I am working with i see 71 stamped in the side of the block. any help as to what i need to make this motor fit, on what everyone told me was a bolt in swap. the 368 motor i pulled is gone now i scrapped it after pulling the few parts i thought i needed.
    the APEMAN is offline Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    598
    Re: 368 to 472 swap issues
    Do you have 368/435 RWD motor mounts or the ones with a huge stud sticking out?
    Both 368 and 472 were used in FWD and RWD and you could have a custom pan too.
    Pix?
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,027
    Ape would know more than me, but I recall that 368 cars that have 472/500s swapped in have to use the 368 oil pan. Perhaps that is the issue.
    Mar 2010
    54
    598
    RWD '77 up 472 and 500 swap can use a 368 or 425 pan along with oil pickup.
    The 368 oil pickup has a different style seal to the block so be extra careful to make sure it isn't sucking wind.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    The 368 oil pan bolts up to the 425, 472 and 500, but when using on the 500 the very bottom has to be hammered or dimpled to clear the rod bolts, they can just touch the bottom. the pick ups are a different story. The pick up will not fit a 68 or 69 block, they fit a 70 on. But the tab that bolts to the main bearing has to be bent and a new hole drilled. I am using a 368 pan on a 70-472 and this is what I have done.
    Mar 2010
    54
    598
    If you need a picture of a 1980 368 that came out of a Fleetwood to identify your situation just holler.
    Sep 2011
    41
    4
    Mts had the correct pan for me. USED and mailed in a bag in box dripping at my doorstep. rear sump and pan bolted in perfect after 3 days cleaning pan. but now my newest issue. upgraded the transmission as recommended. but its cross member-tranny bushing mount is not lining up and my drive shaft is to long HAHAH DAMN projects. Being a Cadillac rear wheel drive 368 motor frame and drive train under my 48 Packard body. is there a way to figure out what years used this setup? Sadly the old motor and transmission wher removed from my yard by illegal scrappers while out of town, so i have no old parts to reference. so im not sure what tranny will fix this issue and survive a 472 motor and not take major cut and welds to make fit. any ideas? its a stock cadi frame and drivetrain just no idea what year or make
    May 2003
    Massachusetts
    1,210
    Pictures would help. If you are going to put in a TH400 transmission , they came with 3 different length tail pieces. Changing the transmission from one length
    tail to another means taking the internals out of the transmission.
    Sep 2006
    Ontario, Canada
    44
    8,027
    368 was 1980 and 1981 only (up to 84 for commercial chassis). RWD, DeVille and Fleetwood only. It would already have a TH400 in it. Driveshaft is easily shortened by any local driveline shop (or by you with a cut off wheel/grinder and a MIG welder).
    Mar 2010
    54
    598
    There are still places that can cut and rebalance driveshafts. Find one and ask them exactly how to measure twice so they can cut once.
    Any idea how much the Packard weighs?
    May 2003
    Massachusetts
    1,210
    I thought the cross member was the problem. Is it worth all the cutting and welding instead of just getting the right part that fits? The 472's were all with long tail shafts and all the 425's and 368's were bolted to a short tail shaft.. The early 400's had better parts inside and more metal in the case. I would change the tail....
    Sep 2011
    41
    4
    OK so I got a th400 tranny and i will have to move the cross member back and shorten the drive shaft, sorry for not posting sooner i had internet issues, 3ne3m03p85T55Z25U3b7i1d71f23e89ff11f3.jpg this is the car im working with
    May 2003
    Massachusetts
    1,210
    How long is the tailshaft on the th400 you have?
  16. #14
    Mar 2010
    54
    598
    Here's some Packard eyecandy for inspiration from one of my other hobby interest sites:
    http://amfone.net/Amforum/index.php?topic=36767.0
  17. #15
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    399
    [QUOTE=Howsha Fern;12940402]OK so I got a th400 tranny and i will have to move the cross member back and shorten the drive shaft, sorry for not posting sooner i had internet issues, 3ne3m03p85T55Z25U3b7i1d71f23e89ff11f3.jpg this is the car im working with [/QUOT
    If you had an 80s 368 frame & drive train, you should already have a TH400, which bolts right
    up to a 472/500. I wouldn't change anything with the drive shaft or trans mount. If the time
    comes to go through the trans, it can be built up some with 472/500 parts and still fit the car.
    Bruce Roe
  18. Remove Advertisements
