Timing Issue 472 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
500, 472, 425, 368 Discussion, Timing Issue 472 in Cadillac Engine Discussion; Hmmm. I jumped the gun and purchased a used HEI from a 472 for $41 including shipping on ebay. I'm ...
  1. #16
    Nrets is offline Cadillac Owners Member
    Sep 2005
    37
    Re: Timing Issue 472
    Hmmm. I jumped the gun and purchased a used HEI from a 472 for $41 including shipping on ebay. I'm finding out that I'm going to need to replace a number of other parts too. And do a minor rewire. I'm wondering, now, if any of these kits you guys are talking about come with the coil and other things like possibly the wires and cap and rotor that need to be changed for the HEI conversion?
  2. #17
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    The HEI distributor is coil-in-cap so if you got a complete one that should be about all you need. You must've gotten it from a 74... The wires will be seperate no matter what distributor you get. The cap, rotor, coil, and ignition control module are all cheap parts-store items and if you end up buying them all seperately you'll still pay less than one of the reman distributors.
  3. #18
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Proform makes an HEI tuneup or rebuild, whatever you wanna call it kit for like $80. Comes with ICM, rotor, cap, coil, weights, and springs.
  5. #19
    74eldog is offline Cadillac Owners Fanatic
    Automobile(s): 74 Eldorado
    May 2005
    Columbus, Ohio
    149
    Quote Originally Posted by davesdeville
    Ok, i have a 74 eldo with a 500 cid and have yet to tear it apart.... It does have the stand alone coil so does that mean this particular model has points in the distributor?
    I'm thinking yes but want to be sure because i will upgrade to hei.
  6. #20
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Make sure to bypass the resistor wire too, the HEI wants a full 12v+
  7. #21
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Quote Originally Posted by 74eldog
    That's about what a HEI distributor looks like. If yours is significantly different (sounds like yours is,) upgrade.
  8. #22
    May 2005
    Columbus, Ohio
    149
    thanks, i looked at it last night, it doesn't have the coil in the cap....
    I'm going junkyard huntin this weekend for some other stuff and maybe I can run up on one......
    Any, makes and model will work with the 74 caddy....500 engine
  9. #23
    Sep 2005
    37
    Hey, just wanted to thank everyone who gave me advice on changing to HEI. I ended up getting that 41 dollar used distributor on ebay and it basically was ready to drop in. It came with the cap and rotor and coil and everything else. I put it in and it ran rough. Then I played with it and it ran . That was some beuatiful stuff. I currently have left the car behind in SOcal as it has column wiring issues that caused 2 starters to get stuck on, decapitating the bendix housing in the first one and literally cracking the other starter in two. I have given up on the car in the time being..but as for switing to HEI, it definitely is a thing to do. The car ran at least as smooth (with used parts) and it was nice knowing the points wouldn't go out of whck every 3 oil changes or so.
  10. Remove Advertisements
