fuel pump outlets
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, fuel pump outlets in Cadillac Engine Discussion; Just finnished installing the 500 in my 4x4 truck.The fuel pump has two ports coming from it.Since i do not ...
    deeman is offline Cadillac Owners Member
    Apr 2004
    13
    fuel pump outlets
    Just finnished installing the 500 in my 4x4 truck.The fuel pump has two ports coming from it.Since i do not have a return lines to my dual tanks,can I block the other outlet off or would there be problems?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: fuel pump outlets
    You can block the return off. It's there to lower fuel temperature at the carbonator inlet. If you have problems with hot restarts then consider plumbing a return line to the tank.
    Apr 2004
    13
    Thanks Ape Man ,I just blocked it off and it seems to work fine so far.A real problem that I have is that I run each tank seperately so having a return line would be a PITA.
