What are these holes??????
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, What are these holes?????? in Cadillac Engine Discussion; I have a 75 500 that came out of a Sedan Calais and was replacing the gaskets. When I put ...
    lead sled is offline Cadillac Owners Member
    May 2005
    16
    I have a 75 500 that came out of a Sedan Calais and was replacing the gaskets. When I put the heads back on I noticed that there was a hole that I didn't remember being there when I took the heads off. It's really strange. If I look in the hole it runs all the way through the head, like somebody put a pipe that runs the length of the head from front to back. Both heads have this same feature. I took alot of digital picutres but can't find a good picture that shows what was there to begin with. I also don't remember removing (4) plugs either.
    Anybody know what these are for or what to do about them now???
    Thanks Wayne
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: What are these holes??????
    Sounds like the A.I.R. injection setup to me. Was the car equipped with an A.I.R. pump? They use a crossover tube between the front of the 2 heads. The tube is held in with a Crow's foot gizmo similar to that used on a distributor but smaller.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I'm sure all 500's of that era had AIR injection. You can just thread it for a pipe plug, or re-use the system.
    On my 1972 472 I had the holes in the valve ports filled and the intake on the end of the heads was plugged.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by caddydaddy
    Unless you happen to live in Kali-fornia.
    May 2005
    16
    No there isn't an A.I.R. pump. There was a big diaphram on the passanger side exhaust with a tube running to the front of the engine, but nothing on the driver side.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The valve on the exhaust I believe is called the EFE valve. I think it runs off of engine vacuum, and that's the line you saw. The emmissions label should mention whether there was an AIR pump to begin with. Most likely it was removed.
  9. Remove Advertisements
