Code 25 on 81Cadillac Seville 8-6-4 V-8
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, Code 25 on 81Cadillac Seville 8-6-4 V-8 in Cadillac Engine Discussion; Check engine came on... cc display showed code 25. Also, bottom door courtesy lights will not come on and under ...
    wpgresh is offline Cadillac Owners Member
    Jul 2005
    6
    Check engine came on... cc display showed code 25. Also, bottom door courtesy lights will not come on and under dash courtesy lights com on when I press the brake pedal. Need help. Thanks, ... wpgresh@atlanticbb.net
    kc81cadman is offline Cadillac Owners Member
    Automobile(s): 81 Sedan DeVille 8-6-4
    Jan 2005
    Toronto Ontario
    20
    Re: Code 25 on 81Cadillac Seville 8-6-4 V-8
    Codes, no clue (not enough experience yet). Electrical is something you really have to trace out from the light back. Having a schematic helps alot.
    KC.
