Header gaskets...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
500, 472, 425, 368 Discussion, Header gaskets... in Cadillac Engine Discussion; Hey guys, just wondering something... The gaskets on my exhaust headers are completly shot so I have soem major exhaust ...
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Header gaskets...
    The gaskets on my exhaust headers are completly shot so I have soem major exhaust leaks. Anywho I need to replace them. Do I need to torque them to a certain extent or what? I can get ahold of a torque wrench but don't knwo how to use one. Any help here?
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Header gaskets...
    *bump*
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Haynes lists these torque specs.
    Exhaust manifold to cylinder head
    Long Bolt 35ft.lbs.
    Short Bolt: 12ft.lbs.
    Says you should work from the center outward.
    Just to clarify, headers are a tube (primary) for each exhaust port that dump into a collector. An exhaust manifold is basically a single tube for all the ports, which is what you have (or at least what's original on these cars.)
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    you must retorque header (or manifold) gaskets, especially the paper ones.
    About the next five or so times you drive the car, go and retorque all the bolts (after it has cooled). Both the bolts from the header to the engine, and exhaust to header.
    The LARGE temp swings that these parts take makes the retorquing nessacary. Really, you should keep torquing them between drives untill you don't have to turn them any more for them to be torqued.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Alright, thanks a lot guys.
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    46
    1,258
    You're probably going to work pretty hard to keep from breaking the exhaust manifold bolts. I'd spray them with a good penetrating oil every day for a week or so before even trying to loosen them. When you do start to loosen them, use some heat and then move the bolt back and forth (loosen then tighten a little......repeat) until they are removed. It'd be a good idea to continue to spray them as you loosen them too.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Sounds great, thanks lux. That would have never crossed my mind. I appreciate the extra input.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Oh, lux, by the way....
    I've been spraying the bolts for about 3 days now. Going to keep going at it until the new gaskets arrive (3-5 days) I'm using that PB stuff.
    Just wondering, when you say that I should use heat, what kind of heat are you talking about? I know I can't use a flame of any kind due to teh fact that there will be loads of highly flammable penetrating catalyst everywhere...
    Thinking about breaking the bolts has really got me worried about all of this. Is it really that easy to break a bolt?
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Just looked again, and it says 35ft lbs for long bolt and 12 for short bolt. What length would be considered long? What length would be considered short? I'm going to get new bolts and just need to knwo this.
    BluEyes's Avatar
    Feb 2005
    595
    You can use propane around PB Blaster, I have. Yes, it burns, but it isn't like gas or anything. You'll see some yellow flame when you have the torch on a puddle of the PB, but it doesn't continue burning after you take the torch away.
    If you're really nervous, just give it a day without spraying the PB blaster before using heat.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Alright, thanks for all of the help guys. It didn't even occur to me that replacing gaskets would be this tricky.
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Anyone on the long/short bolt situation?
    Jan 2003
    Ohio
    46
    1,258
    I believe the short bolt are on the ends but that won't matter until you torque the new ones down anyhow.
  16. #14
    BluEyes's Avatar
    Feb 2005
    595
    Well, once you have the bolts out, it should be apparent which are long and short. Just take those to the hardware store and get some nice grade 8 replacements of the same size/length.
    You will probably want to put washers under the new bolts, unless you can find bolts that have the same flat shoulder that the stock ones have.
  17. #15
    May 2005
    El Dorado, Arkansas
    26
    1,631
    The bolts are all the same size. Well, here it is. This car has had some real shoddy work done to it.
    All the bolts on one side are pretty long, and on the other side, they are short. They are all the same length per side though.
    I've got all but 4 of the bolts out. The other ones still won't budge and I am scared of breaking them.
  18. Remove Advertisements
