1975 Eldorado temperature sending units
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, 1975 Eldorado temperature sending units in Cadillac Engine Discussion; Upper radiator hose blew by ignition cap causing fire in front of engine. Three wires burnt. One goes to the ...
    Thomas E Burke is offline Cadillac Owners Member
    Automobile(s): 1975 Eldorado
    Dec 2013
    Upper radiator hose blew by ignition cap causing fire in front of engine. Three wires burnt. One goes to the HEI cap the other two I believe go to the temperature
    sending units. The two colors of the wires are green and orange. Which goes where?
    Thanks for any information!
    Tom Burke
    68
    81,922
    Re: 1975 Eldorado temperature sending units
    I moved your thread to the engine forum where I think you may get more help.
    bluegrill is offline Cadillac Owners Member
    Automobile(s): 1975 Coupe DeVille
    Oct 2012
    42
    Thomas,
    According to the wiring diagram in the 1975 service manual, the wire to the dist cap is pink, the wire to the coolant sensor is dark green and the engine temp sensor is light green.
