Distributor/breakdown syptoms?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, Distributor/breakdown syptoms? in Cadillac Engine Discussion; Could a faulty distributor cause my car to idle rough,backfire,hesitate,stall,lack power and make the check engine light and the MPG ...
    bluecor is offline Cadillac Owners Member
    Oct 2004
    54
    Could a faulty distributor cause my car to idle rough,backfire,hesitate,stall,lack power and make the check engine light and the MPG screen flicker, ?
    Thanks
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Distributor/breakdown syptoms?
    Indeed. I'm not too sure about the MPG screen flickering but it could definately cause the other symptoms you mention.
    Oct 2004
    54
    Hi Davesdeville
    I've noticed that when i remove the No.8 spark plug wire from the distributor the check engine light stays off and the MPG screen doesn't flicker when i give it gas, although the car misses,
    Any ideas as to whats wrong
    Thanks
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Try switching it with another wire and see if the same wire will do the same thing in a differant positon. If so you should probably get a new set of wires.
  7. Remove Advertisements
