transmission fluid refill....
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, transmission fluid refill.... in Cadillac Engine Discussion; ok, another silly question for you *long time* caddy drivers... I want to drain my transmission and give it a ...
    king of the road is offline Cadillac Owners Member
    Apr 2005
    28
    I want to drain my transmission and give it a refill with fresh fluid...so where do i fill it up please?...
    JoeBob1901 is offline Cadillac Owners Member
    May 2005
    9
    Re: transmission fluid refill....
    I dont know if the caddy trannys are any different than others i've filled up..but normally i just drain the fluid, drain the torque converter, put a nice rubber gasket on the pan, retorque the bolts, then refill with a flexy small ended funnell with tranny fluid
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    The transmission dipstick tube.
    Apr 2005
    28
    drain the torque convertor?, im new to auto transmissions, so please tell me more of how and why i should do this please!!...
    May 2005
    9
    have no idea on chevy trannys..at least on a ford (E40D) you open up the inspection plate and drain it there....Sry i'm not more help
    dogger is offline Cadillac Owners Member
    Automobile(s): 2001 sts
    Nov 2009
    1
    where to i find the tranny refill tube (dipstick) on a 2001 sts?
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Should be a plastic handle somewhere on the drivers side of the engine/transaxle , similar to the engine oil dip stick, that has "transmission" on it.
  10. Remove Advertisements
