1976 500 rebuild pics part 2
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Like Tree6Likes
500, 472, 425, 368 Discussion, 1976 500 rebuild pics part 2 in Cadillac Engine Discussion; Sorry the pics did not upload on my first try. Dang technology!...
    davidp1561 is offline Cadillac Owners Member
    Automobile(s): 1976 eldorado convertible
    Mar 2013
    50
    70eldo likes this.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Re: 1976 500 rebuild pics part 2
    Looking forward to see more pics!
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    Are you keeping it fuel injected? Do you have the computer and wiring harness?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    What was the cause of the super bent pushrods?
    Mar 2013
    50
    yes I am keeping it fuel inject and planning on keeping the computer and wiring harness
    There were actually 3 bent rods but those two were the worst. The engine actually would still run but obviously acted like it wanted to jump out of the car. These rods were from the cylinders that had the lowest compression when I did the comp test. Not sure what the cause of it was but suspect it was run at very high RPM or it had jumped time maybe but the engine is at the machine shop now so will know soon.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Have you considered a modern EFI system for it? The one on there is so ancient and not as user friendly as newer systems.
    Mar 2013
    50
    I have thought about it but wasn't sure how it would work with the old ecu and then not sure about the cost of a new one as well. may have wait to switch to a new EFI when I have more $$ available.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    They can get kind of pricey, but they include new ECUs, fuel pumps, wiring, throttle body, etc. http://www.summitracing.com/parts/fs...-kit/overview/ If you're planning on keeping your Eldo for a long time, and driving it a lot, it might be the best option in the long run, besides converting it to a carburetor.
    70eldo likes this.
    Mar 2013
    50
    Yes I agree. I will get one but will be down the road after I get the motor back in and see how things work then
    May 2003
    Massachusetts
    1,210
    These old F/I systems had two fuel pumps.. One in the gas tank and one on the frame rail.. If this is on the eldo the best thing to do is replace the in tank fuel pump with a high pressure pump and take off the pump on the frame rail and plum it straight though .. A Walbro 255 pump is what I have used. Bruce Roe's wiring mod to run the pump can safe problems later on with the ECM.. What he suggests is have the ECM run a relay to power the pump instead of having the ECM power the pump.. By doing that the ECM won't burn up that circuit ... This is just one of the things to do to keep these systems going...
    70eldo likes this.
    Mar 2013
    50
    Thank you for that info. I will be sure to do that before driving it this spring.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Don't even consider a carbonator. Night and day difference on a Cadillac engine.
    Keep a spare ECU and temp sensors, maybe use a different cold air bypass. The originals are pretty hard to get.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by The Ape Man View Post
    I will say that my old EFI 500 was the smoothest idling engine I've ever owned! But, like you said, parts are getting hard to find. Lots of them were converted to carburetor for that reason.
  16. #14
    Mar 2013
    50
    what would be the recommended aftermarket efi system for this engine?
  17. #15
    May 2003
    Massachusetts
    1,210
    The question is, what are your skills? If you have not spent days upon days working on your car fixing stuff it might cost more than its worth.. If I had a stock 76 eldo and just wanted to keep it stock , I would keep spare parts do a few mods like I said and keep it going.. Ok if you were going to rewire the engine control system in the car , could you do it yourself ? If your paying someone else to do your work , you don't know what you are going to get... Anyone that will do a top notch job , that's not your buddy working for nothing, will cost a ton of money... If you had a spare ECM , if one had a problem , you can have it fixed and still have one to keep you going.. The sensors are now for sale new..
  18. Remove Advertisements
