'68, 472 HEI Conversion?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, '68, 472 HEI Conversion? in Cadillac Engine Discussion; Hey guys, I got a 1968 Deville, with the 472, with points ignition. The motors out right now being rebuilt, ...
    68deville&99escalade is offline Cadillac Owners Member
    Jul 2004
    17
    Hey guys, I got a 1968 Deville, with the 472, with points ignition. The motors out right now being rebuilt, and before i put it back in i want to switch over to hei. Im thinking about purchasing a replacement hei distributor off of autozone, that is for a newer 472 hei caddy. What else would i need to purchase / do to get it to work properly, thanks.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: '68, 472 HEI Conversion?
    You will need the distributor cap, rotor, ignition coil negative terminal spade (inside cap), spade terminal with clip for distributor b+, ignition wires, wire hold down clip and plastic coil cover. You can buy most of this stuff from a parts house but sometimes the screws are not included.
    The advance curve will almost certainly be off so be prepared to make changes.
    Sasquatch's Avatar
    Sasquatch is offline Cadillac Owners Fanatic
    Mar 2004
    Bluff Creek
    322
    Check out this thread. It has everything you need to know with great links to install procedures. I love my HEI I installed in my 69.
    Hei INSTALLED!
    Here's a real good link with install instructions.
    http://www.oldengine.org/unfaq/hei.htm
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Here's a post I did a year or so ago......
    http://www.cadillacforums.com/forums...10&postcount=7
    Here's the complete thread........
    http://www.cadillacforums.com/forums...&highlight=hei
    Changing from points to hei on a Caddy is no different really than any other GM product. There are lots of articles on different websites that give good, detailed info on this swap.
    Good luck.
    BTW....there is a Oldsmobile site that has lots of good tech info ( http://www.442.com/oldsfaq/oldsfaq.htm ). It's not Cadillac but much of the info can be used on other GM makes, including Cadillac.
    Below is a link to their ignition page.
    The swap is covered....in detail.
    http://www.442.com/oldsfaq/ofign.htm#Ignition ......click on the Points to HEI Ignition link.
  7. Remove Advertisements
