425 missing on one cylinder
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, 425 missing on one cylinder in Cadillac Engine Discussion; When I was driving back from a 30 mile trip, the engine oil pressure light came on if the rpm's ...
    7.0,hellyeah is offline Cadillac Owners Fanatic
    Apr 2004
    134
    When I was driving back from a 30 mile trip, the engine oil pressure light came on if the rpm's dropped below 1500, then after shutting it off to get gas, when I restarted the car, the engine started shaking quite a bit. When I got the car home, I removed all the spark plugs and found that the #2 had lots of unburned gas and carbon on it. I tried using a new plug, but no dice. Now, in order to get the oil pressure light off, the engine needs to be at about 3000 rpm. Here's some advice I got: 1.Oil filter clogged 2.cat may not be letting air out of the engine fast enough; too much backpressure; overheating 3. Head gasket blown around the #2 cylinder. I don't think the later is true though, because the engine isn't smoking at all, i'mm pretty sure its just gasoline in the chamber. I tried a different spark plug wire, but didn't work. The missing cyl. problem started suddenly, but the oil psi problem was a long process. Any imput at all will help, thanks!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: 425 missing on one cylinder
    The missing in the cyl and the oil pressure problem would seem to be 2 differant problems. Are you using the original oil pump? How long since you've had an oil change? Distributor cap look ok?
    Apr 2004
    134
    What happened was the bolt holding in the lifters broke, the lifters popped out, and a pushrod got kicked up under the valve covers. Luckily nothing fell into the oil pan and nothing got damaged. I fixed it fairly easily. Does anyone know what the bolts(rocker arm retainers) should be torqued to?
