Gave my 472 a quick physical today
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, Gave my 472 a quick physical today in Cadillac Engine Discussion; Did have a chance (finally) to do some general tests on the engine. I found the engine serial number and ...
    chrisntam is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Deville Convertible
    Oct 2012
    North Texas
    309
    Did have a chance (finally) to do some general tests on the engine. I found the engine serial number and fortunately it matches the VIN number on the car! Vacuum level is good, about 22 inches, but the needle is not completely steady. It bounces pretty good but only within about a half inch of vacuum. Did a compression test, one cylinder is 137, one is 145, three are 150, two are 155 and one is 160. Oil pressure is 30 to 35 warmed up and at idle. I also found the primary throttle shaft on the factory quadrajet has a bunch of slop it.
    So it appears the bottom end is good (or as good as can be expected for a 43 year old engine), but either the lifter(s) or the rocker arms are clattering quite a bit. Before I bought it, it only had 10 miles put on it in 12 years (or so the repair documentation says). I'll do further investigation on the clattering as time permits. I'll also check the cam timing gear too. Maybe, it just needs a set of ported MTS heads, ported factory intake, a carb rebuild, an MTS #10 cam, new lifters, a street roller timing set and shaft rocker assemblies. I think after all that, I'll be good to go!
    Will let you know how it goes.............
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Re: Gave my 472 a quick physical today
    Carb rebuild and timing chain are what I would go after first for good running and insurance.
    Long live the 472's!!
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Yes, it probably had the nylon coated timing gear set, and I'm sure the bottom of the oil pan is full of those nylon chunks! With a new timing set and a rebuilt carb and basic tune up, it'll be good for a long while!
