1976 eldorado engine rebuild
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, 1976 eldorado engine rebuild in Cadillac Engine Discussion; I am rebuilding my 500 engine and one of the things I will be doing is installing an MT #5 ...
    davidp1561 is offline Cadillac Owners Member
    Automobile(s): 1976 eldorado convertible
    Mar 2013
    50
    I am rebuilding my 500 engine and one of the things I will be doing is installing an MT #5 cam from MTS. This is one step above the base or factory spec cam. My question is will I need to reprogram my ecu for this cam?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 1976 eldorado engine rebuild
    Your ECU is not reprogrammable.
    One thing you can do is get an adjustable fuel pressure regulator and increase the pressure a few percent.
    Otherwise there are aftermarket fuel system$ which can take advantage of the cam.
    Mar 2013
    50
    Thank you sir for the information!
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,182
    Another thing I heard of some guys doing was wire in a variable resistor in place of the temp sensor so by telling it was still cool it would richen it up by the dial of the resistor..
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    Quote Originally Posted by drmenard View Post
    of the resistor..
    A 76 EFI system has a rather simple minded curve, completely open loop, and with no ignition
    control at all. But it is not true, that it can't be retuned. Varying one resistor can shift the
    amount of fuel (injector pulse width) to match a different displacement, or breathing. I have
    already done this multiple times making 350 ECUs run 403s. Easy to do while driving.
    Changing the temp sensor resistance is a very poor approach to the issue. This was well
    demonstrated when comparing the methods on the Maidment Haverhill car project. This
    adapted a 350 EFI to a highly modified 403. I don't have the details on my PHOTOBUCKET
    just yet. Bruce Roe
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Why do a rebuild and use a different cam? It will require a lot of other fine tuning which makes the project unnecessarily complex, without getting noticable gain. Unless you want a lot of gain for racing I would stick to the original setup to have like-new state of engine which will give you plenty of performance to cruise.
    Mar 2013
    50
    Well according to the guys at MTS the cam I would like to use wont require anything like that. I can use the factory valve train etc. It's one step up from the basic factory type cam. I know I am taking what they say on faith since I am not a mechanic but MTS seems to know their stuff.
  10. Remove Advertisements
