Eldorado 368 oil pan ?s
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, Eldorado 368 oil pan ?s in Cadillac Engine Discussion; Will a rear sump oil pan from a 368 powered Eldorado fit the bigger motors 425, 472, 500? I got ...
    fslay is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Coupe DeVille
    Jan 2005
    Mississippi
    100
    472, 500? I got one and didn't know. Thanks
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,208
    Re: Eldorado 368 oil pan ?s
    It will fit all of the motors . But on the 500 a little hammer work is needed.. At the very bottom some dimples must be made for the rod bolts.. Sometime they just touch the bottom and the hammer is needed.. So check the clearance. and one more thing, on the pick up tube , the tap that bolts to the main bearing is a little lower on the bigger motors, not sure about the 425 if its lower or not, but the tap must be bent and a new hole put in closer to the end of the tab..
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    And don't forget to double check your clearance between the pickup and the pan bottom.
