Exhaust manifold leak
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By jukelemon
500, 472, 425, 368 Discussion, Exhaust manifold leak in Cadillac Engine Discussion; Well, lifters and new rockers are in. Quieted that piece of the puzzle. Now on to the exhaust leak. Driver's ...
    jukelemon's Avatar
    jukelemon is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Jul 2013
    Louisville, KY
    60
    Driver's side has a very bad leak. Took it to a good shop and they confirmed.
    They want 300 to fix the leak (gasket), replace both Y gaskets and check/fix if necessary the heat valve.
    Question is this..
    Should I just go buy some headers?
    I will NOT be hot rodding this engine but for 300.00, I would think I could get some nice headers to go into the stock Y pipe.
    The rest of the exhaust is fine i.e. just need the manifolds fixed up.
    Thoughts?
    Thanks all.
    Jason
    Roadmaster75's Avatar
    Roadmaster75 is offline Cadillac Owners Member
    Automobile(s): 1978 Eldorado Biarritz
    Feb 2012
    Illinois
    59
    Re: Exhaust manifold leak
    Jason
    What kind of engine/car is it?
    Also, be very aware of the likelihood that one or more
    exhaust manifold bolts will break off in the head. That $300 doesn't take that
    into consideration.
    It is VERY difficult to extract these while in the car; and sometimes impossible without
    removing the head. SO, be prepared to cross that bridge if you hand the car off to that shop. You should be able
    to find stories about this on this and other forums. I had no less than four bolts break off due to rusted away shanks.
    Luckily it was on the stand and the machine shop properly removed them while they were in for the valve job.
    The trouble is
    that the shanks of the bolts rust away, then snap off at the slightest twist of a wrench.
    Also, be very sure it's a gasket issue NOT a cast iron CRACK in the manifold. Very common.
    That would be the deciding factor on headers or not.
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Sorry. 68 Deville. 472.
    I am aware of the issues...I am hoping that does not happen.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Roadmaster is 100% correct. Along with that your engine doesn't have y pipe gaskets at all and didn't come from the factory with exhaust manifold gaskets.
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Hi Ape.
    I was reading about the lack of gaskets from factory.
    However, mine has them in the manifold for sure...you can clearly see them. Cannot comment on the Y pipe other than it sure looks like a gasket to me when I look. Maybe not?
    Is it jacked up to have manifold gaskets? Seemed to me (from reading) that it is common to have manifold gaskets on engines that have had work done.
    Not sure.
    Thanks all.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by jukelemon View Post
    Hi Ape.
    Not sure.
    Thanks all.
    That's good news as the manifold bolts may not be ancient. I always opt to leave the exhaust manifold gaskets out as god intended.
    Still no gaskets in the y pipe.
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Got it back.
    What a difference. MUCH quieter. Fixing that side (which was very loud) allowed us to hear the PASS side leaks lol. There is a small one on that side.
    At some point, studs were put in the head i.e. no more bolts and the mech said the DR side came off pretty easily. Good news.
    He said mine was pretty warped and could not be cut down true so he found a used set that was in perfect shape.
    I thought about doing the PASS side myself considering this news.
    Seems pretty straight forward.
    Kind of pisses me off that I chose the Lifters first. In the end, the lifters were fine I guess. It was fun tearing into them/the intake.
    That tick was definitely the manifold. Now, I just hear a very small leak and the sound of that muffled big block. I dig it.
    The Ape Man and 70eldo like this.
  10. Remove Advertisements
