Gasket cement for Valley Pan?
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Gasket cement for Valley Pan? in Cadillac Engine Discussion; Hi all. 68 472. When I pulled the intake man gasket off this last time, there was 0 cement on ...
    jukelemon's Avatar
    jukelemon is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Jul 2013
    Louisville, KY
    60
    Hi all.
    68 472.
    When I pulled the intake man gasket off this last time, there was 0 cement on the gasket.
    FSM calls for it.
    Do you all use it?
    Thanks.
    Jason
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Gasket cement for Valley Pan?
    I like RTV silicone on one side of the gasket and a little 3M weatherstrip adhesive on the other. Silicone on both sides would act as a lubricant before curing and may allow the gasket to come out of place.
    Neither of these choices were available when these engines were designed. If it were a newer engine the thing would probably call for RTV silicone and no gasket.
    Always allow 24 hours for RTV silicone to fully cure.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    I think they are referring to keeping the part from moving around while assembling.
    (I may be wrong)
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Thanks all. That makes sense.
    They probably used a cement/shellac back then. Like I mentioned, there was nothing on it when I removed it.
    The damn intake is so heavy you could probably not torque the bolts and it would be ok
    Feb 2005
    Southern NJ
    54
    2,096
    Intake is 57 lbs. I leave the carbonators on when working on these because it's only a few percent more.
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Yep, that is what I did as well.
    No reason to replace a carb gasket as well when it will both come off easily.
  9. Remove Advertisements
