68 deville 472 rear main seal???
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By The Ape Man
500, 472, 425, 368 Discussion, 68 deville 472 rear main seal??? in Cadillac Engine Discussion; Rear main seal is leaking, which way is the easiest way to replace it? Taking the motor completely out?? Or ...
    wowllis is offline Cadillac Owners Member
    Automobile(s): 1968 cadillac deville
    Sep 2013
    1
    Question68 deville 472 rear main seal???
    Rear main seal is leaking, which way is the easiest way to replace it? Taking the motor completely out?? Or just the trans??? Any info, hints ,tips are greatly appreciated!! Thanks in advance!
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,173
    Re: 68 deville 472 rear main seal???
    The way to change that seal is not that hard. The first thing is unbolt the exhaust.. then take the nuts off the bottom of the motor mounts. now with the hood open, jack up the motor at the crank pulley.. Try to get it about as high as you can... Now you should be able to get the oil pan off.. after the pan is off take the rear main bearing cap off... Now the seal is a 2 piece and can be changed .Now you have to push the top half out of the channel and its easy to put in the bottom cap and just put it back together... Use oil to lube it up to help you get it in over the crank.. If you have a hard time getting it to go in the top you may have to loosen all the main bearing caps to let the crank drop down enough to let the seal in... Take your time and try to keep it as clean as you can..
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Are you 100% sure it's the ream main seal? Oil pressure sender is right up top where it can make oil do funny things.
    cadillac_al likes this.
    May 2003
    Massachusetts
    1,173
    you are so right about the oil pressure sender.. Have seen the rear main get blamed for that before... But I think we are wasting are time.. wowllis has not been back since he posted the question... Dave Menard
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by drmenard View Post
    That happens. I was away from here for several years myself.
  8. Remove Advertisements
