1980 Coupe Deville Ignition problem
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1980 Coupe Deville Ignition problem in Cadillac Engine Discussion; I have a 1980 Coupe Deville with the California emissions. I was driving it every day until the problem arose ...
    slayer10242 is offline Cadillac Owners Member
    Automobile(s): 1980 Coupe Deville
    Jun 2011
    44
    4
    I have a 1980 Coupe Deville with the California emissions. I was driving it every day until the problem arose about 8 months ago, and it has sat in the garage since. Heres the problem:
    I changed the plugs, wires, cap and rotor, air filter, and pcv valve. About a week later, I was on my way home and it died, and the dummy light came on that says stop engine oil pressure. I checked the oil, and it was fine, so I tried to start it again and it wouldn't start. Turns out, I had no spark. I pulled the cap off and found that I didn't seat the cap properly, and the rotor had been digging into the side of the cap. I replaced the cap, and still didn't have any spark. I replaced the Ignition Control Module, and it started, ran for about 20 seconds, and died, with the same dummy light. This also shorted out the Ignition Control Module, again. I had the car towed home and have slowly been working on it again. I replaced the Oil Pressure sending switch, and rebuilt the Oil pump, and installed it today. I started the car and it fired right up and ran. While it was still idling, I added some transmission fluid (as there is a mysterious puddle under the car that wasn't there until late winter) and was going to take it for a ride, when it died after about 10 minutes of running, with the same dummy light, again, and no spark when I try starting it again. What is causing it to short out the ICMs? It really sucks because thats three I've been through, and being CA emissions, they are around $40.00 each. HELP!!!
    Jun 2011
    44
    4
    Re: 1980 Coupe Deville Ignition problem
    BTW, it is the 368 c.i.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I have never heard of them failing that quickly. I think they can test them at the parts stores. You should test your old ones to see if they are really dead. Maybe the coil is acting up somehow; never seen one kill ICM's though. Are you putting the grease under the modules? Even if not they shouldn't die that quick.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Some of these ( perhaps I should say most new production ) ICM s are manufactured somewhere other than here and I doubt the quality is anywhere near what the original GM Delco units were. I have noticed that they are much more fragile and prone to failure than the original GM Delco units. There is a tester listed in the SM, but I have never seen one and there are probably variations of testers for the different model years and new generation (Calif., other) modules. Most test procedures determine that the module is defective after testing every other unit of the HEI.
  7. Remove Advertisements
