Results 1 to 6 of 6
Thread: 546 stroker with tbi
    chevrolac is offline Cadillac Owners Member
    Automobile(s): 92 brougham 87 brougham
    Apr 2013
    indiana
    35
    8
    will it supply enough fuel if i put a high pressure pump in tank
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: 546 stroker with tbi
    YES all day long.
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,201
    What computer are you going to use to run it?
  5. #4
    Apr 2013
    indiana
    35
    8
    i am using the 7427 ecm i started it it sounds pretty good but i drove it and it shifted into overdrive at 40 so i had to reprogram the drac box and i need to finish my exhaust
  6. #5
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    Quote Originally Posted by SafariOne View Post
    YES all day long.
    I would think that larger injectors will be needed. GM did, using larger units on the TBI 454 units.
  7. #6
    Apr 2013
    indiana
    35
    8
    i am using the 94 95 tbi with what i believe are 45 lb injectors with the higher 32 psi pump and i drove it today and it is running very lean
  • You may not post replies
