running without air pump?
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, running without air pump? in Cadillac Engine Discussion; I got a 368 carbuerated motor and i was wondering what would happen if you run it without an air ...
    cadillac_81 is offline Cadillac Owners Member
    Nov 2012
    22
    I got a 368 carbuerated motor and i was wondering what would happen if you run it without an air pump, cause mines locking up
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,183
    Re: running without air pump?
    Taking off the air pump and the rest of the parts on the system won't hurt a thing... Most guys want to get rid of that stuff... But to take off that stuff you will need some non air pump pulleys... They made your pulley system so if you take off the air pump fan belt the alt. will not turn... So what you can do is get a crank pulley and waterpump pulley off a non air pump car . They were on some 76 cars with a 500 and most 77-79 cars with the 425 motor... Find a donor car and get the two pulleys and if you want to neaten it up get the alt brackets off the donor car.. the ones you have will work but the bracket that was made for no air pump looks better...
    Nov 2012
    22
    Thanks for the info, i took off the air pump and bought a belt that drives the water pump crank and alternator, the power steering has its own belt and when .i got it, it didnt have a AC compressor. I just install the belt and thats it!!! It runs way better without pulleys. My car is an 81 but the engine and tranny is from a 80, this is the diesel model i have but the engine was swapped and tranny years ago
