What's the best way to replace a water pump on a 76 deville
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, What's the best way to replace a water pump on a 76 deville in Cadillac Engine Discussion; What all is needed to replace the water pump on a 76 deville and easiest way on the 500...
    Colto45o is offline Cadillac Owners Member
    Automobile(s): 1976 deville
    Jan 2013
    4
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: What's the best way to replace a water pump on a 76 deville
    There are no shortcuts. First U need to remove the radiator fan shroud from the radiator support and hang it on the fan. Then the radiator, so it does not get damaged. You can then crack the bolts holding the fan to the pump stem. If you have the clutched fan, you can remove this first. Loosen the assesories so the belts will come free. Remove the extention from the pump stem. Last remove the pump from the front cover. Good idea to drop the coolant and flush the system with a neutralizer before you start all this. I covered all this on another post here recently. Search my posts and you will find the explanation there. When you replace the pump it is a good time to replace all the hoses.
    Jan 2013
    4
    Thanks I appreciate that
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,933
    If you look in the RWD section, I posted pics of the water pump replacement on a 368 (same procedure as 500) in my coupe project thread.
  7. Remove Advertisements
