Results 1 to 7 of 7
Thread: water wetter
    Nov 2012
    22
    water wetter
    Has anyone used water wetter in their engines??? Let me know if its good or not
    Roadmaster75's Avatar
    Roadmaster75 is offline Cadillac Owners Member
    Automobile(s): 1978 Eldorado Biarritz
    Feb 2012
    Illinois
    59
    Re: water wetter
    I have used these products with both street cars and a methanol fueled
    dragster (no radiator, no water pump; just water and "wetter" in the block).
    In the race car it helps, but keep in mind it's only running for a total of about a minute;
    and then only 8 seconds in anger....
    I have noticed a a slight improvement in temperature control in
    a couple of hot rods with high performance engines & custom radiators.
    In a stock Caddy, however, I don't think you need it. If a stocker is running hot
    it's best to isolate the culprit and fix it. Water wetter won't cure a systemic problem.
    my 2 cents
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,846
    Re: water wetter
    yeah, that ^^^
    Various "water wetters" will not do a thing for a daily driver engine/cooling system. The 50/50 coolant mix plus a 16 psi pressure cap insures that the coolant will transfer max heat from the engine metal to the air.
    Consider that, if your thermostat is set to begin opening at, say, 180 degrees, no amount of magic potion on earth will cool the engine to below 180. And any daily driver engine, run too cool, rapidly carbons up and develops oil sludge because nothing heats up enough to boil off the contaminated moisture and acids in the crankcase and oil itself. There are good and valid reasons for 180+ degree thermostats and PCV systems. (and short stop & go trips are the worst thing in the world for an engine. You get less oil and engine wear on a 1,000 mile Interstate trip to wherever than you get in two weeks of city driving.)
    Here's what a 140 degree thermostat does to an engine........................
  5. #4
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: water wetter
    Yeah, X2 on the 140 thermostat. The engine becomes a sludge pump.
  6. #5
    Nov 2012
    22
    Thanks guys for the info!!! So a 140 degree thermostat is bad for your engine, is a 195 degree thermostat a great idea for your engine??
  7. #6
    69
    82,272
    Re: water wetter
    Use what the factory spec'd for your year and engine (probably 195).
  8. #7
    Feb 2006
    56,846
    Re: water wetter
    Quote Originally Posted by cadillac_81 View Post
    Cute, but maybe not. A gasoline engine seems happiest when operating at around 185 - 205 degrees. Most "180 degree" thermostats start opening about there and are fully open at about 200. Using 50/50 coolant and a 16 psi pressure cap raises the boiling point to 265 degrees - a 65 degree cushion. A 195 thermostat would run the engine at ~210, only a 55 degree boilover cushion.
    A 180 degree 'stat runs the oil at ~190 - 220, the ideal temp to cool the reciprocating machinery and boil off moisture and acids. Running the oil hotter leads to breakdown as well as increased machinery temps. (NO coolant touches the crank, pistons, rods, chains, cam, lifters,etc. - only oil cools those parts.)
    (As Ranger posted, run whatever 'stat the factory used originally. 195 seems a bit too hot for a pushrod engine............. whatever)
  • You may not post replies
