whats the best fuel filter???
Results 1 to 13 of 13
500, 472, 425, 368 Discussion, whats the best fuel filter??? in Cadillac Engine Discussion; Hi im new to the forums, i was wondering whats a good fuel filter for a quadrajet carb, i got ...
    cadillac_81 is offline Cadillac Owners Member
    Nov 2012
    22
    Hi im new to the forums, i was wondering whats a good fuel filter for a quadrajet carb, i got a 1981 cadillac brougham with a 368 4bbl. Thanks!
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: whats the best fuel filter???
    Isn't your 1981 368 TBI fuel injection?
    Nov 2012
    22
    Nope, its the diesel model but around the 90s the drivetrain was swapped to a 368 4bbl with a turbo 400. I bought it a year ago!
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    [QUOTE=cadillac_81;3147848]Hi im new to the forums, i was wondering whats a good fuel filter for a quadrajet carb, i got a 1981 cadillac brougham with a 368 4bbl. Thanks![/QUOTE
    Check rockauto.com
    Nov 2012
    22
    Thanks Creeker, ive been to rockauto.com love the site i havent shop there for filters before just parts.
    Nov 2005
    3,013
    I used to own a 80 cdv. with a 368, there is not much variety in these filters, have you installed one before?
    Nov 2012
    22
    Yea, in the inlet its a cardboard filter, i heard that back than they use a stone like filter you can reuse and theres the inline ones if you have the rubber lines not the metal ones.
    Sep 2006
    Ontario, Canada
    44
    7,931
    Your choices are paper or sintered bronze. Personally, I would run an inline filter between the pump and the carb (and that is exactly what I do on my carb cars).
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    The sintered bronze filters are 1950's and early 60's tech. Actually very effective, but slightly restrictive. Can be used as a pre-inlet in-line filter. Your filter is located in the carb inlet housing itself. Disconnect the fuel line and then the 1" nut. In back of that you will find a paper filter, seal and spring. The seal should be replaced, but no longer comes with the filter as it used to, so you have to reuse the seal if you don't have one at your disposal.
    Nov 2012
    22
    Thaks guys for the info! I hear good stuff about the inline filters. I might go towards the inline
    Feb 2003
    california
    69
    6,663
    I prefer the in line as well. The filter in the inlet at the carb allows water to settle in the threads, and can eventuall corrode the threads, ruining the carb. Use flare nut wrenchs on these fittings at the carb or you will damage the nuts or twist the metal fuel line!! On an inline filter install, use hi pressure fuel injection hose and euro type hose clamps ( they grip the hose, not cut into it). The drier gasoline today will eventually dry out regular fuel hose and be a potential fire hazard! Ask me how I know! These euro hose clamps can be gotten at any foreign auto parts store.
    Nov 2012
    22
    Thanks for the info carnut! Where can i get these foreign type clamps at? Can u get me a list where i can get em and a pic of how they look like?
    Feb 2003
    california
    69
    6,663
    I will bite my tonque on where to get them. re read above post! Should I pick them up as well? Not knowing where you live, how do I recommend? I just did a GOOGLE search for "euro style hose clamps" and found hundreds.
  16. Remove Advertisements
