81 fleetwood brougham
Results 1 to 13 of 13
500, 472, 425, 368 Discussion, 81 fleetwood brougham in Cadillac Engine Discussion; Just wanted to know the good and the bad about the 8-6-4 motor. How much mpg do you get too....
    uso
    uso is offline Cadillac Owners Member
    Automobile(s): 79' Coupe , 81' Fleetwood Brougham D'Elegance
    Oct 2012
    Milwaukee, WI
    7
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: 81 fleetwood brougham
    the 8-6-4 or 6.0 or 368 motor is a dependable low power motor.. The best gas mileage I ever got on the highway was 19mpg...But let me say that was with the 8-6-4 disconnected, thats running on all 8 all the time... around town 15 at best... but that was years ago...
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    A friend said he saw 21 mpg on the road, with 8-6-4 functioning. Bruce Roe
    uso
    Oct 2012
    Milwaukee, WI
    7
    Oh ok thanks guys. I just bought my 81 and can't wait to get on the road with it. I think I'm just goin to keep the 8-6-4 functional
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Bruce has the correct info.
    There isn't much of a downside. The 6 cylinder mode vibrates but is only a transition between 8 and 4.
    All the original complaints with these cars EXCEPT the 6 cylinder vibration were DEFI related and later accepted as normal.
    uso
    Oct 2012
    Milwaukee, WI
    7
    How do I know if the 864 is turned off cuzz I keep checking it on the electronc gage that tells u how many cylinders are running and its always on 8.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    The orange wire from the transmission is likely cut.
    Feb 2005
    Southern NJ
    54
    2,096
    There were also PROMs available to disable the 8/6/4.
    sevillejussi is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    8
    Quote Originally Posted by The Ape Man View Post
    Hi, The Ape Man
    What do you mean, could you tell us more?
    Sep 2006
    Ontario, Canada
    44
    7,931
    He means that the dealership disable the cylinder deactivation feature (when customers complained that 6 cyl mode was vibrating) two ways. One (like my car), they cut the orange wire that sends the high gear signal to the computer that the trans is in 3rd; or, by actually swapping in a different computer that does away with the deactivation. Check under the car first.
    Feb 2005
    Southern NJ
    54
    2,096
    Not the whole computer just the PROM chip. Somewhere I've seen a list of GM PROMS and some were listed as 8/6/4 disabling.
    uso
    Oct 2012
    Milwaukee, WI
    7
    I'm gona have to checc on that...both the wire and the PROMS.
    Feb 2003
    california
    69
    6,663
    If the wire is cut, run the wire thru a toggle switch. Mount the switch at the bottom of the dash. Switch off until you reach freeway speed then flip the switch to engage 4 cyl. mode. The only thing problematic is the plastic valve covers tended to crack if the owner or mechanic was not careful replacing the gaskets.
  16. Remove Advertisements
