Correctly wiring the sparks on a 500
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, Correctly wiring the sparks on a 500 in Cadillac Engine Discussion; Before I bought it, someone with more enthusiasm than smarts worked on this 72 Eldorado. The red battery ground wire ...
    dochawk's Avatar
    dochawk is offline Cadillac Owners Enthusiast
    Automobile(s): '72 Eldorado Convertible, '97 Eldorado ETC, '01 DeVille DHS
    Feb 2009
    Las Vegas
    742
    Before I bought it, someone with more enthusiasm than smarts worked on this 72 Eldorado. The red battery ground wire is merely annoying, but the starting motor only worked because of a hanging stray wire, and so forth . . .
    Today I set out to replace sparks and wires, one by one. Thinking it a bit odd that consecutive cyinders on the same side of the block should fire one after the other (maybe they should; I really don't know), I went to the Chiltons in the back seat (or maybe it's the other brand; I've bought both).
    I can't tell which direction is which in that diagram (does the wheel shown in the diagram mean the front or back of the engine, as compared to the car?), but whichever direction it is, it sure isn't how this thing is wired at the moment.
    Before taking the carb out for rebuild, it was gettin a whopping 4 MPG. It blew 2% CO (1.2% allowed).
    Is there somewhere I can find a wiring diagram or picture so that I can tell how they *should* be on here, instead of how they are (the carb also had it's vacuum lines wrong. I'm also pretty sure that GM didn't ship it with a wood screw terminating a vacuum line . . .)
    thanks
    hawk
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    374
    I have an ign wire picture on the second picture of this PHOTOBUCKET
    album, lower right corner.
    http://s93.photobucket.com/albums/l7...L%20INJECTION/
    Get a factory service manual, get the vacuum hoses renewed.
    It sounds like the engine needs all kinds of help. Likely the timing chain is
    shot; check it out. I assume tires are current. Every time I get a car, it gets new
    front calipers, brake hoses, and front lines (304 stainless is good). Cause, I
    don't want any big surprises if I jam on the brakes. I do the rear too, maybe
    a little later. And gas tanks often start leaking, mine come off about every
    15 years. good luck, Bruce Roe
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: Correctly wiring the sparks on a 500
    X2 on what Bruce said about a factory manual....really the best spent money for information. Sometimes they can be found on Ebay.
    Miklo II is offline Cadillac Owners Member
    Automobile(s): '76 FW Brougham d'Elegance (R.I.P.), '75 SDV (57k,2nd owner)
    Oct 2012
    15
  7. Remove Advertisements
