Proform GM HEI Distributor Tune-Up Kit
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, Proform GM HEI Distributor Tune-Up Kit in Cadillac Engine Discussion; Does anyone have an opinion about thus kit. It seems like a good value if the quality is good....
    bluegrill is offline Cadillac Owners Member
    Automobile(s): 1975 Coupe DeVille
    Oct 2012
    42
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Proform GM HEI Distributor Tune-Up Kit
    Pro-Form is a secondary distributor of aftermarket auto parts. Without knowing what the kit is comprised of, I can not asertain it's value towards enhancing your distributor. Does it contain electronic parts or is it a selection of weights and springs?
    As far as your HEI is concerned, make sure the centrificals are working properly along with your vacuum advance can.
    Oct 2012
    42
    Sorry I meant to include a link to the product. It includes:
    Adjustable Vacuum Advance Unit
    Advance Spring And Weight Set
    And Mounting Hardware
    Contains High Power 50000 Volt HEI Coil
    HEI Bushing; Wire Harness And Capacitor
    High Performance Low-Saturation Control Module
    No Arc Rotor; Coil Dust Cover and Alkyd Cap
    http://shop.advanceautoparts.com/web...8-p#fragment-2
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    The price looks good, for what parts are included. I see that the cap has brass terminals instead of aluminum, which is a plus for sure. And the new wire harness is a good item too...
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It looks like a decent kit to me. I usually buy complete distributors for less than that, but they don't make them for Caddys. (last time I checked)
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    The main advantage is that you will no longer need point adjustment for the distributor!
    It will not give you any performance gain.
    GM_Parts_Guy is offline Cadillac Owners Member
    May 2013
    4
    I personally have used the Pro-Form dist rebuild kits. For stock replacement applications I haven't had a single issue. Pro-Form also makes some other products that I have used and been impressed with. If looking for top of the line or a performance application I would look to MSD Ignition Systems. They make dang good products and I run their stuff on all my preformance vehicles.
    May 2013
    4
  11. Remove Advertisements
